Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
so online tubing is like $23857293573495734 but I could just go to homedepo and get the same shit for 5 bucks, does the temperature matter or anything?
just get it from svc or sidewinder, its not that expensive...and i dont think home depo carries laboratory grade tubing, does it? it would probably be too stiff, become discolored, or warped. not worth risking it with a wc loop that could fry your whole rig if it leaks/breaks.
Your coolant of choice can also evaporate through certain tubing materials. I don't lose much at all, maybe 1/4" per month in my tee with 1/2" Clearflex tubing, no evidence of leakage in the 5-6 years I've run this loop. Tygon has a different rate, don't know it off hand.
i use tygon 3603 1/2" ID 11/16" OD, distilled water, and swiftechs hydrx coolant/corrosion inhibitor mixed in. daemas' suggestion of a killcoil is also good!
if you need to make really tight bends, get something softer than what i suggested though. theres no space in my mid tower and after a while, the tightest bend started to kink just a little bit. then again my tubing is fairly thick so that makes it harder for small curves. something to think about...
