does this system work? noob needs advice:)
hey, im kind of new to putting together pc's.
i want to buy a new mobo that supports pcie (currently on agp:( )
and i want to get a new processor and gfx..
so i looked around and i think this is in my budget
Intel ATX E6300 CORE 2 DUO 1.86 ghz (does this come with a cooler? when bought separately?)
ASUS P5L-VM-1394
HIS x1950XT 256mb OR
HIS x1950pro 512mb (help on the choice here would be cool:p)
ill be bringing these from my old setup.
maxtor 6Y080P0
maxtor 6L080P0
iCute 600w power supply (duel 20a 12v rails)
2x 512mb 400mhz ddr2
and some lg dvd burner:p
ohyea and.. can you run 400mhz ram with 533 mhz ram? or is that bad haha.
and.. i mainly chose that mobo because it has 4 ram slots. as i already have the 2x512 400mhz so im probably going to buy another two 512s... or a 1g so if anyone can find a cheaper board that would support all that id appreciate it :D thanks.
