Does this sound right to you?
Obiwanshinobi900
Alright so this is my second water cooling loop. Its been awhile since I put my last loop together. I have a mountain mods UFO opti 120.3 case and a thermochill pa 120.3 radiator. I plan for the loop to to as this :
Res up top -> radiator -> pump -> cpu block -> back to the res. Will my pump be able to push the water through this? Here is a picture of what I have so far:
(just ignore the massive amount of wires and fingerprints)k
those D5 pumps can push through alot more than that trust me :)
you might want to put the res before the pump but apart from that seems fine to me.
The D5 is easily enough for this application. Hell, you could throw some SLI'd FC waterblocked cards into the mix and it'd still power through.
