Nightcaste
- Mar 11, 2006
I'm new at this high-performance computing stuff, so I'm not sure if what's happening here is right. Here are the details of what I have and I'd like to know what's normal or wrong or what.
Mobo: MSI KT4V (MS-6712)
CPU: AMD Thunderbird 1.1 Ghz (not OCed)
Case: Antec 1050B SOHO server
Fans: 2x 80mm front, 1x 80mm GPU, 1x92mm CPU, 1x120mm rear
All of the case fans are Antec, and everything except the big 120 in the back are aimed for intake.
The CPU cooler is a ThermalTake, not sure the model or anything, it was the one recommended by the guy at Microcenter for a Socket A.
Here's what's going on: The cpu temp is about 50 degrees Celcius at idle, and the CPU fan turns about 300 more RPM with the door closed than open, but the temp doesn't change. I would like to know if this is normal, or if I should change some things around.
