JonMichael
- Feb 14, 2005
Alright, well I got all my stuff in the mail yesterday. Everything ran perfect, especially for a budget build - but I have a few questions about hardwares physical well being. Not everything was a tight fit, most of it was smooth... but the heatsink/fan for the CPU and the actual RAM both had VERY tight fits. I expected that from the RAM, seeing as it has happened to me before. But the HSF kinda scared me. I put it on facing the opposite way the manual said, but then I read further and it said that the way I positioned it was also fine. What scared me was the huge gap between the actual bracket on the mobo and the clips on the HSF. So I tried many different methods, but I finally resorted to the manuals directions. It said to push down until you heard four clicks, which was obviously a good ways down. I pushed quite hard, and I heard the clicks - but I think I may have bent the board a bit. The fan also bumped some little round thing over a little, but I fixed that. All of the clips are perfect, the fan runs great... but I am just a little worried about the board. I inspected it, and it looked fine. Will it hurt the board if it is bent just a little? Hopefully Im not the only one this has happened to. I was just curious as to if this has happened to any of you guys.
The PSU was also a tight fit, but that has happened to me many more times than once.
