Does this PC look ok?
tillyoubreakit
Hello guys, after years of Laptop bordom i decided to get back into the whole "desktop thingy" and so i designed a cute little PC. Do you guys see any faults in the configs or have suggestions? Its gonna be used as a worstation and a game PC and server duties.
Lian Li PC7S
Thermaltake 750 Watt
Intel E6600 Core 2 Duo
Abit AW9D Max2
2x 2048MB Corsair DDR2-800
4x WD 74Gig 10K Raptors in Raid 0
2x 768MB GeForce 8800GTX in SLI
2x 500Gig External backup drives
Floppy and NEC DVD Burner
My 2x20.1 16:10 screens...
Are there any complications with the SLI function or the cards and this board? Sorry but my last big rig was a Vapochilled P4 2.6C at 3.9....so its some time away
"cute" PC?
That thing is more like a brutishly brutal brute force of brutishness PC
I hope you enjoy it! God knows I would...
I would have gone with 650i or 680i if I was using Nvidia Graphics, staying with Abit though, you may want to read up on their upcoming 680i IN9 32X-Max if I wasnt in a big hurry for my Rig, I would have definately been waiting on the reviews for this bad boy.
Boy $600 extra to run sli? That CPU can't even push 1 Geforce 8800 to it full potential let alone 2 of them.
http://www.tomshardware.com/2006/11/29/geforce_8800_needs_the_fastest_cpu/
Save that $600 and buy some DirectX10 Games when they come out here in the next month or so. Your not going to need another video card for awhile.
1. Please don't spurt Tomzhardware figures in here because they are complete and utter bullshit and with an aftermarket cooler that e6600 should be able to go into the 3.4ghz-3.6ghz region
@op: For the powersupply get a PC Power and cooling 750w or a silverstone which Bbq will be recommending: http://www.newegg.com/Product/Product.asp?Item=N82E16817703008
For the mobo go with the EVGA 680i as that abit board has zilch overclocking potential.
I do see 1 major problem, an SLI setup will handle 1 monitor not 2 so your gonna have to be turning off SLI if you want to use your other screen.
Anyways rest is fine and enjoy it :)
Beat me to it. btw, you don't need sli with only 1600x1200.
At 1600x1200 sli would already give an advantage because starting at this resolution, games are most likely GPU bound when all settings are max. A higher resolution is better. You don't need a faster CPU at a higher resolution because your GPU will be the bottleneck and your CPU still has more headroom. Btw would it makes any difference, when playing at a lower resolution you'll get about 150fps because your CPU can't push the GPU to its full potential and you'll get about 200fps when your CPU can push the card to its full potential?
That Abit motherboard in your list doesn't even run SLi, it's crossfire only. 975x chipset.
Like others said, go with 680i, like the EVGA or the new Abit.
While SLI would definately help, he's got a dual monitor setup, so it really wouldn't be practical. A single GTX would be more cost effective and still give you great performance, since SLI isn't really needed. Two 8800GTX's in SLI is overkill for a 1680x1050 monitor. But hey, if you want it and got the cash for it, then by all means, go for it.
Thanks for the help guys. I am gonna switch to the new Abit board. Abit IN9 32x MAX 680i Well, how is the Asus P5N32-E SLI nForce680i ?
Should be a fine machine.
Thanks
Flo
