astrallite
- Jan 9, 2008
Does this LCD monitor exist under $2k?
1. 25.5" or larger
2. IPS panel
3. External Power Supply/Power Brick (so no annoying buzzing/high pitched noise).
4. (not a deal breaker) height adjustable.
5. (also not a deal breaker) HDCP compliant
I have a NEC LCD 2690wuxi which has all but #3 (and is a noisy sucker) and I've been testing out an Apple Cinema 23" which is as quiet as you can ask a big LCD to be, but it lacks everything the NEC has asside from noise. In other words, it's worthless to me asside from the peace. Now the 30" apple simply isn't worth it to me since it lacks pretty much any redeeming features in its price range aside from an external power supply. If it fulfilled #1-5 I certainly would buy it.
Now the Dell 3008wfp sounds like the ultimate monitor I would want, but it's also got an internal power supply--and I hear it buzzes quite a bit too.
A note I would like to add--I'm fairly certain I don't have a defective LCD, the noise level does not change with brightness or sound horrdenously loud like some of those youtube videos. I have a silent PC and a well dampened room, and the NEC monitor is the loudest component in the room.
Now if someone knows a DIY method to quieting down a power transformer in an LCD monitor, I'm all ears.
1. 25.5" or larger
2. IPS panel
