I am looking for a micro atx motherboard with a specific slot layout (if such a board exists).
I need a board with 1 x16 PCIe slot and 1 x4 or greater PCIe slot. The other 2 slots can be anything. The problem is the positioning of the slots. I am looking to put the board into a 2u rackmount case, and so will be limited to low profile, 2 slot cards. I also have a low profile SAS RAID card to use. Because the dimensions are so tight, and I really need to keep things as quiet as possible, I want to give the graphics card as much room to breathe as possible to give it good airflow. Unfortunately the PSU in the case is right up alongside the edge of the mobo, so just putting the graphics card in the lower SLI slot won't work.
Basically, I think I have 2 options for layout:
(looking down on the board, rear connections towards you)
CPU....x4 slot.... x16 slot....Any slot....Any slot
OR
CPU....x16 slot....Any slot....Any slot....x4 slot
The first option allows the graphics card room to breathe before the PSU interferes, the second option spreads out the RAID card & allows the graphics card space over the unused extra slots. The RAID card slot does not have to be an x4 slot - an x8 or x16 will do, but x1 will not give enough bandwidth.
If possible I would like to go s775, but will consider a PhenomII board if there is one. If this is confusing let me know & I will try and explain it better.
The case I intend to use is here.
Does such a motherboard exist? Or will I just have to put up with more noise and use faster GPU fans?
Thanks for any suggestions.
OR
