Hello fellow members of the mighty [H]orde
I just downloaded the A2 core for F@H, I got 2x 2662 WU's. They are running single client native Ubuntu v8.04 (with a KDE4 desktop) I have each one of them on Q6600 G0's, OC'ed 3.0 GHz (9x333), 2 GB's PC6400 RAM, stock vcore and both are WC'ed. The below pic of FAHmon 2.3.2b is showing about 5000 PPD a piece
I went to the FAHlog.txt and it shows a time frame of 5 to 7 mins. I know that can't be right, I sure wish it was
, I'm asking anybody's advice on how to make the FAHmon program more accurate and just how much I should add to the frame times (?FAHmon = last frame only, last three frames, effective rate or all the freakin' frames
The diskless are E6600's, OC'ed 3.0 GHz (9x333), stock vcore (I'm anal bout' temps
I did notice the CPU usage was better with the A2 core and I'm usin' the v6.22 client, but so far I've only run it for about an hour and a half. (keepin' my fingers crossed I don't see any "early end" type errors
Thanks in advance for any help
Edit: Correction, 1x Q6600 is only OC'ed to 2.8 GHz, the other is OC'ed 3.0 GHz (or pretty close 9x333)
FOLD ON!
FOLD ON!
