Panel Type: TFT Active Matrix LCD
Native Resolution: SXGA 1280x1024
Pixel Pitch: 0.264 mm
Brightness: 300 cd/m2
Contrast Ratio: 450:1
Response Time: 12 ms
View Angle: 150° / 135° (Horizontal / Vertical)
Input Connectors: 15-Pin D-sub
Dimensions & Weight: 14.8"x 15.5"x 6.3"(W x H x D), 11.0 lbs.
I don't use DVI as I can't tell the difference between DVI and VGA analog.
I'm going to this from a crappy Compaq 1725 Monitor
