TheBuzzer
HACK THE WORLD!
- Aug 15, 2005
Scythe Ninja / Inf or Tuniq Tower
which one fits in antec P180 case with an EVGA 680i mobo?
Bbq said:They both work. I would choose the scythe ninja instead of the tuniq, since on a p180, it's almost perfectly aligned to both 120's, and with a bit of ducting, you can run it passive.
TheBuzzer said:wow thx, that thing is huge but it fits
looks like you even got the 680i with the nivida chipset fan thing.
oh just wondering why did u got an extra fan?
oh ya, i dont see you used the fan controller addon that came with the heatsink/fan so what speed is it using if that thing isnt attached?
Full speed unless he rewired the connector to run it at 5 or 7 volts.TheBuzzer said:oh ya, i dont see you used the fan controller addon that came with the heatsink/fan so what speed is it using if that thing isnt attached?
TheBuzzer said:oh ya . easyshadow is the fan that goes inside the heatsink replaceable by any 120mm fans?
if it is i might start searching for 120mm fans that have the new PWM thing
don't make blanket statements that simply aren't trueTuniq Tower over the Ninja anytime, i have both of them and Tuniq Tower 120 is way better.
