Does this 3DMark11 score look right? 6950
Suxen
Unlocked MSI Twin Frozr II 6950 at 880Mhz core and 1375Mhz memory.
What are you guys running your settings at?
Thanks
my unlocked 6950 at 900/1425 does 5700~ so I would say you are perfectly acceptable.
Score seems about right.
My unlocked 6950 @ 980/1375 scored P6202 and P5162 at stock.
Thanks guys. What were your voltages? I ran into a weird error, ran 3Dmark11 fine and Kombuster fine but then crashed in less than a minute of Counter Strike Source. It froze the computer completely. Voltage issue?
I run 1.18v for my max stable OC on my 6950. Sounds like you may have a possible unstable OC. I have found that Kombuster is not good at all for testing OC's and 3dMark11 is usually off a bit as well but better than Kombuster where stable is generally 20-50mhz lower than what I can Max bench 3dMark11 with (depending on card). Games are better tests and one of the best gpu stress tests I have found is Crysis2 at/near max settings for 20-30 minutes. If you do not crash and see no artifacts, chances are pretty good your OC is pretty stable. I've been able to game with BF3 and Metro2033, but Crysis 2 would crash after a bit letting me know I needed to dial it back a hair more.
900@1.125 is my everyday setting, 950@1.175 if I'm wearing my IEMs and won't notice the noise.
