does thermal paste get old / need to be replaced?
indokyne
So my nVidia 5900 Ultra is starting to overheat and it hasn't really done that before. I'm using an Arctic Cooling NV Silencer 4 rev.2
I clear out the dust in my case and fins pretty often so there's no cloggage...
the only thing i could think of is that maybe I should re-apply the heatsink / fan and thermal paste...
or does it not matter once a good seal is achieved?
Have you done any overclocking? Remember that once you are artifacting, the damage is already done. As a last ditch effort, I would apply the paste, but I wouldn't keep your hopes up.
i may sound kinda newbish but i don't think it's ever artifact'ed...
I don't overclock the card but I was kinda surprised that it's spec'd at 850MHz memory
it just shuts down outta nowhere.
Speedfan shows 65+degrees C while I'm playing games - some pretty standard ones
(PoP TTT - 1024x768 normal settings / Trackmania etc).
Is there a way I can tell whether this card has reached the point of no return / fried?
Thermal paste dry out can make a difference. Basically, it becomes an insulator when dried out, so if it's on thick enough, it will get worse over time.
If you have something like AS5 spread very very thin (almost non-existant) it will probably not make a difference over time.
You mean that because my card artifacted once when it was overclocked, that it's damaged now?
What?
That's the point of overclocking, you back off 5-10mhz after you start artifacting. As long as it doesn't run too long artifacting, than it should cause no damage to the card...
