LOL, I cant recall how many posts Ive seen in the old days of how stupid CL was for not giving ppla way to plug in headphones and such from the front, now that they have done that ppl say their stupid because they didnt shove 20 connectors onto the back of the card. Maybe if enough ppl contacted CL they might make some sort plate with connectors for those that don't wish to use a drive bay, sort of like the deal that came with my older cards. Personally I really like the front bay as it puts everything in my reach and no more crawling behind my computer if I wanna switch to say headphonesbanGerprawN said:I'm fairly sure that the only optical out you will get with the X-Fi is in the form of the front drive bay thing that comes with all the models except for the base one. I consider that to be a huge pain in the arse, having to run your cable from the front of the computer. Stupid idea, Creative!
Not really, unless your Speakers pwr button is close how do you mute the speakers when you want to use just your headphones. I'm not saying its a must have thing I just do recall at one time there were lots of complaints about accessability of connectors or that they were too close together which the drive does solve. I did say they could maybe offer a simpler version of connectors on a backplate that would take an unused card slot (sorry for not being clearer) like came with my SBLive I think it was. Then those who want something in back have it. I'll probably rarely use some of the connectors myself unless I decide to drag my old Tivo DTV box into my office and that would only be temp so plugging in from the front is definitly handier for me.Soul.Survivor said:Even if I did want wires hanging off the front of my case I couldn't use it because of the BIG METAL DOOR on my case. My solution is to get a $3 y-connector from radio shack and hook speakers and headphones up to the same plug, wow, I'm just a freakin genius aren't I.
Soul.Survivor said:It's a Kenwood reciever, I turn the power off. I think an add on for a pci slot with optical/rca connectors would be ideal but I'm sure some people would have problems with that. I just can't imagine having fiber cables hanging off the front of my pc. Even worse, RCAs.
Soul.Survivor said:You would hang rcas off the front because that's where the AUX in is located, I shouldn't have mentioned that I guess since the AUX in really doesn't matter for most people. And the headphones have in-line volume so I guess you could turn them down all the way if you really wanted to, I don't usually mess with that though.
