Does the OCZ GameXStream has long wires??
Ignacio49
Hello.
I need to know if the the OCZ GameXStream has long wires.
I already bought the OCZ GameXStream, but I will have it in my hands next week. Now I am buying the Cooler Master Ammo 533 case, which has a hard drive cage located at the bottom of the case and sits sideways. For this reason, the distance between the psu and the hard drives is longer than usual.
Thanks for your help.
It should be long enough.
Pro tip: Set the drives so the part where you attach everything is facing the mobo tray side. Works wonders.
Sorry, I don't get it. AFAIK the drives can be set in one way only, and the part where everything is connected faces the case`s side wall.
Bbq, I believe I understood your answer ( my English ..the one to blame...). Do you mean setting the drives in "reverse", 180 degrees, with their connections side facing the "other" case wall (the one alongside the mobo) ?
If you attach the braces on the drives backwards, you may be able to fit them into the cage that way. That would keep the cables out of the way. Usually, though, what I do is put the drives in the 3.5" bays above the "drive cage" proper. There's more room (in my case, anyways) for them in the backwards position there.
I don't know for sure about the GameXtreme, but the Fortron Epsilon units that they are based on have extremely long cables. I'm sure you'll be fine. :)
