I'm not sure I understand why you recommend the GPU to utilize all cores? It lowers the GPU production if I have it run across all cores and the SMP production doesn't compensate. Mind you, the only quad I have is AMD so it might be different with Intel.You can use it with the GPU now... before the issue was that we could not tell the GPU to use all cores... now you can and thus AC + 2xSMP + GPU on a Q6600 is now the best combo.
Is that with one GPU client or two? Which OS?With a Q6600 my production might drop a total of 100PPD on the GPU, but I pick up 2x SMP for about 2.5-3.0k+4.9K for the GPU (just throwing out a #). If I only run one smp then it is maybe 2-2.25K + say 5k for the GPU.
In the end I am netting about 500-750 PPD on average by using them this way. The problem with just limiting it to one core is if the SMP or AC decide to load core 3 heavily my PPD on the GPU can plummet to about 2-3k... Spreading the GPU to all cores does drop it slightly, but my points will always remain at that level.
