Does Suspend Mode turns off system fans??
Saeid
Whenever i put my Intel D945GNTL in suspend mode (Start>Turn Off System>Suspend) its as if my Pc has shut down. All the fans and LED's turn off.
When i want to turn it back on, i have to press the power key (the Keyboard and Mouse dont work), and within 2 seconds its loaded up and ready to run.
My previous PC was a P4 2.4C with MSI 865PE mobo, and whenever i put it in suspend mode, the LED would go out or turn orange (cant remember) and i could hear the HD turning off, but the case fans as well as the CPU fan and the mobo fan would continue to work. And with the touch of a button/key the system would return back
My question is, is there something wrong with my system right now? Is it normal for the case fans and CPU fan to turn off, and when i want to bring it back i have to press the power button? Is this the new trend to cut down electricity usage? And finally does this happen to u guys too?
Thnx in advance!
There's two different suspend states your PC can be in - S1 and S3, which you can select in BIOS. One of them will shut down all your fans etc, the other keeps them, plus other components running. It sounds like your new PC is using the other setting to your last one.
You can also enable wake up by Mouse and Keyboard if you have those settings in bios.
I personally have it set to S3 (Everything off) and I wake up by USB remote and/or mouse.
Look in the power section of your bios.
thnx for the response guys...
just wondering... with everything off... does the PSU draw power? If so does the PSU fan still work....???
Yes and no. It draws enough power to refresh the memory, which is very little. And also depending on your setup the (PS2) mouse & keyboard, USB if any, and NIC.
But no the PSU fan stays off.
