Does something like this exists in DIY shops?
Hitokiri Batohsai
I was thinking of upgrading to a Logitech G27 until I realized that I need to find a way to mount the gear slightly lower than the table I'm not investing in a G27 until then. Since I'm using my pc table (Ikea jerker), mounting the gear on the same height as the wheel is awkward. Does anyone make/sell a slightly lower mount for the gear. I don't want to get a custom racing seat/mounting items since the table is quite sufficient with my current DFGT. Also I don't have the space to place a custom rig. One way of mounting the gear lower is to get a coffee table of some sort and mount it there though I would like to see a table clamp solution which provides a floating platform so that the floor is free from any table. I think this thing exists in a DIY shop. Any suggestions?
i dont see the issue with mounting the shifter at the same level. i use mine all the time and its fine, although having a seat with proper placements would be ideal. the one thing i didnt like about the g27 was they made the shifter an H only, so i stuck with my g25.
That is true. What would be great was logitech made a wheel with DFGT buttons, G27 wheel gears, G25 shifter and fanatec clubsport pedals
