Comixbooks
- Jun 7, 2008
I read a few reviews on newegg saying it won't work with AMD chipsets and someone from Samsung actually replied and said it works with just Intel.
WARNING: DO NOT BUY THIS IF YOU OWN A RECENT AMD MAINBOARD! SAMSUNG DOES NOT, NOR DOES IT PLAN TO START SUPPORTING NEWER AMD MAINBOARDS CONTAINING THE MARVELL CHIPSET.
Nowhere in the product description or in Newegg's own description or when installing the accompanying Magician software was there EVER any warning that this SSD device is COMPLETELY INCOMATIBLE with newer AMD mainboards and specifically the Marvell chipsets they come with. It doesn't even support Micorosft's own certified AHCI driver! After 3 minute boot times, lost data, BSOD etc.. I finally dug deeper and found this out. Newegg should have a disclaimer and Samsung's software should not have told me that my system met all the requirements and proceed to install and corrupt my system resulting in days on end of lost time and data to troubleshoot this. I'll research, but if anyone knows which SSD would work on my 1 year old AMD mainbaord I would love the advice.Meanwhile it's RMA time.![]()
I have a gaming machine with 3.5ghz phenom processor and 8 gigs of DDR 3 memory, Geforce GTX 460.
I contacted samsung about my IOPS random read and IOPS random write only getting about 35% of the speed they are supposed to and about my drive NOT waking from sleep at all unless I completely cut the power to my computer and turn it back on that way.
Samsung would NOT provide support for me they ONLY said this:
Dear Customer,
Thank you for contacting Samsung SSD Support regarding your concerns and inquiries. You mentioned you have an AMD processor and chipset. The reason I mention this is because Samsung SSDs do not work correctly with machines that contain AMD chipsets. Our SSDs are recommended for use with Intel chipsets and because of this you will see performance issues with your SSD. Now concerning your second issue, the AMD chipset may also be responsible for the sleep mode problem that your having. If your looking for maximum performance from your SSD, the best environment would essentially be a windows based machine with a Intel processor and chipset.
