nowshining
- Jan 19, 2006
`when downloading from www.real.com I ran system mechanic pro (free trial from www.download.com) and updated the included spyware applications, when I scanned for any spyware, it reported a realplayer keylogger..
So I deleted it, later on when i had to redownload realplayer from www.real.com and installed it, again I installed System Mechanic pro 'cause I like it so much and another free 30 day trial 'cause I didn't get to use it all up..Updated the spyware scanner again and scanned again, and again another keylogger from realplayer...
So I would check ur systems..I am in the process of hoping that this topic will shed some light on it and if possible for others to confirm this by using the same system mechanic pro program as I did..
If u have broadband itta be best 'cause its about 30+ megs...
