imzjustplayin
- Jan 24, 2006
Does water that is propelled by a fan move the same way as air? I mean you'd use the same type of fan blade angle and everything (use a blade meant for blowing air) and use it to blow water would you get the same effect? The reason I ask is because I'm wondering how exactly does the air move once it leaves the fan blades. It would seem like designing a heatsink that impedes the least would be the most ideal...
