does pci express use IRQ and shit?
mjz_5
i've seen soo many problems, especially with sound cards and IRQ problems. Does pci express eliminate these problems? other then the obviously speed increases, what other notable features are there?
If you are messing with IRQs still you are likely causing the problems.
For a long time now PCI devices can do IRQ sharing without any problems, we are not in the bad old ISA days anymore.
But FWIW: PCI-E motherboards do usually to support high IRQs. Even the laptops I set up recently (centrino 915 chipset) had the network cards on IRQ 18. (a high IRQ)
==>Lazn
I haven't had to manually set an IRQ since Windows 3.11.
Ahh... the good 'ol days IRQ's, DMA's, Base Memory Address'
:D
well, i had problems with my creative SB A2, and tech support told me to place the card on the lowest PCI slot.. It did solve my problem... I'm just hoping these kind of problems will go away.. But come to think about it, the only problems i ever had was with creative sound cards.
