...could it be my monitor?
I recently upgrade to triple displays. I've got three Acer XB271-HU monitors being powered by two Gigabyte GTX 980 Tis. The problem is that when my computer turns off the display, then I wake them up (PC doesn't hibernate or sleep, just the monitors), the left-most monitor takes longer than the others to turn back on. Sometimes it will take 20 seconds or so. Sometimes though, it can take 10-15 minutes. All three monitors have the same brand, brand-new cables.
So I'm trying to figure out if there is a problem with that monitor, or if it's a driver problem. BTW, it's been that way with multiple driver versions.
What do you think?
What do you think?
