Does my ram timing need to match?
darkhunter139
I am upgrading my PC to 4 gigs of ram from 2 gigs (It has one 2 gig stick already)
I bought a stick of ram with the timing 5-5-5-15 before i realized it didnt match my other one which is 6-6-6-18. When I tried booting with both of them in it does not work. do I need another 6-6-6-18 stick in order for it to work?
Which RAM, specifically, did you already have, and also which one are now trying to add?
While ou can set the timing in the BIOS, it usually sets them automatically to the slower of the two sticks. I'm guessing your problem has more to do with voltage than timings, but try manually setting the timings to the 6-6-6-18 setting. What are the voltage ratings for both sticks?
How many sticks are you running? Manually set your voltage to 1.9v if you're using 2 sticks. If you're using four, you may need to bump it to 2.0v, and bump your mch a bit higher. Also set the timings to the lower 6-6-6-18 setting -- set it all using one stick, then add the 2nd stick after you save your settings.
