I've always used bootable CD's or other non-floppy devices. Use nero and a win9x startup disk as a basis. Once you have that as your boot image, place the mobo utility on the rest of the cd with the bios image.
Non-floppy alternatives make this so much quicker and at the rate floppies go bad, safer (IMO).
You will need a disk image tool and your favorite cd burning software (Nero is mine, but others will do), or a flash drive, usb-zip, netboot, whatever your bios will give you.
If you use the cd-rom, use a cd-rw. Just $0.02 advice, or the cost of a cd blank, or whatever....
