Does my BIOS version really matter concerning upper-level CPU compatibility?
I'm upgrading the processor on my MSI K8N Neo4 Platinum mobo and so far had 2 new processors not work on me (computer will not boot with them plugged in). One is the highest Athlon 64 chip my board is compatible with (4000+) and the other is the highest Opteron chip my board is compatible with (Opteron 180). At first, the 180 did get me past the BIOS screens, but then quickly bluescreened before getting to Windows and every subsequent attempt to boot with it in there does not even get me to my BIOS logo screen now. Once I plugged my old chip back in (a 3200+) everything was gravy.
CPU Compatibility chart directly from MSI
The only thing I can think of to fix this is a BIOS update, something I'm not very fond of doing. On the MSI website I notice the "Since BIOS Version 1.D" value which seems to be the latest BIOS version available for my mobo (latest meaning back in 2006 apparently). Should this tell me that the chart being presented here is only compliant with if my mobo has this BIOS installed? I mean, what happens if I bought this board back in the day with a 4000+ instead of a 3200+? I would be screwed, which is why I think it's silly a BIOS update should be needed for CPU compatibility. But anyway, here's a capture of my current BIOS information:
BIOS Version Nvidia - 42302e31
Phoenix - AwardBIOS v6.00PG
BIOS Date 09/09/05
BIOS Web Page http://www.award.com
BIOS Vendor Phoenix Technologies, LTD
Version 6.00 PG
Release 09/09/2005
BIOS Size 512 KB
Characteristics - supports booting from ATAPI ZIP drive
- supports booting from LS-120
- supports legacy USB
- supports ACPI
- Multi Processor supported by BIOS
- supports INT 10 CGA/Mono video services
- supports INT 17 printer services
- supports INT 14 serial services
- supports INT 09 and 8042 keyboard services
- supports INT 05 print-screen
- supports INT 13 3.5-inch/2.88M floppy services
- supports INT 13 3.5-inch/720K floppy services
- supports INT 13 5.25-inch/1.2M floppy services
- supports INT 13 5.25-inch/360K floppy services
- supports Enhanced Disk Drive specification
- BIOS ROM is socketed
- supports selectable boot
- supports booting from CD-ROM
- allows BIOS shadowing
- upgradeable (Flash) BIOS
- supports APM
- supports Plug-and-Play
- supports PCI
- supports ISA
DMI Version 2.3 @000F0BE0
Doesn't look like it's the "lastest" BIOS MSI offers, in fact I can't even see a correlation between anything in my BIOS info that matches "Version 1.x". Looking at the BIOS date and comparing it with BIOS version for my board HERE leads me to believe this is the "Version 1.9" BIOS, certainly not the latest and greatest but is at least the 9th update to this family of BIOS(es).
Now, I'm willing to flash my BIOS if I must, but I hate having to fix things that just aren't broken and don't see why a motherboard that is compatible with these chips won't work without an update to its BIOS.
Can somebody shine a light on my situation and tell me what I should do to try and fix this? Is a BIOS flash really necessary for my situation?
TIA
