- Jul 1, 2004
http://www.monoprice.com/Product?c_id=104&cp_id=10430&cs_id=1043012&p_id=2509&seq=1&format=2
I never have any1 ask this before: this guy has a laptop. He wants the VGA output of the laptop to go in a composite TV selector that has 4 input, and it outputs to an old TV.
It's a gateway laptop, about 1 yr. old. The above link says:
is mono just being careful? Or does most laptop video card support this TV out function?
This item is a VGA VIDEO Card to S. Video or Composite TV Adapter Cable.
Use it to connect the video card on your computer to a TV input. Your video card MUST be able to support s-Video or Composite out through it's VGA port. This is known as a TV out function. If you don't know if your video card can do this, then call the card manufacturer and ask them "Does my video card support S-Video or Composite Video out through its VGA port?" If it does, then buy this adapter. If not, then use Product # 4724 http://www.monoprice.com/products/search.asp?keyword=4724
