- Jul 11, 2001
Are you for real?
Anyone that trys to grind down there CPU is an idiot and should be taken out back and shot...
Seriously what idiot came up with this great idea? I totaly agree with that article 100%
So do you, like the author of the article, also not know the difference between the heat-spreader and the actual core of the CPU?
Anyone who has been building computers since the Athlon/Pentium3 days or so knows exactly what a CPU core looks like because CPU's did not used to come with heatspreaders. Cores are usually small (about the size of a dime or so) and extremely delicate. No one in their right mind would ever sand the core directly...
But back then it was common for people to chip off a corner of the core during improper heatsink installation since you were basically balancing a big heatsink on a tiny fragile core.
a heatspreader is simply an aluminum and/or copper cap that covers and protects the core. When you are lapping a CPU all you are doing is sanding the surface of the heatspreader for better contact.
What is so dangerous about smoothing out a metal cap? Nothing.
Some people even completely remove the heatspreader.
