does it really matter wich thermal compund I get?
donjonson
So many to choose from varied in price and presumably quality? do you think I should spend a lot or a little I will have a core i7 and a XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler. will the cooler include thermal compound and if so should I invest in some higher quality thermal compound?
thank you!
The long story short is no. Most TIMs, though they are often only enough for one use, would do the job without any problems.
If you plan on adjusting your HSF multiple times, however, you may want to get some extra TIM. Though Arctic Silver 5 is still a good choice, it has a long curing time (I believe that it's 200 hours for maximum effectiveness). You should look for some TIM that doesn't have any curing time, like Arctic Cooling MX-2, Tuniq TX-2, or OCZ Freeze.
No.. My mx2 ran out half a year ago and I've been surviving on leftover TIM from various coolers.. Silverstone, AS5, Noctua stuff..
Agree with the other posts. I use Artic Silver Ceramique which seems a decent balance between great performance and reasonable cost. When I buy parts for a system for a guy I usually buy a small tube of that (unless I have some around which is usually the case). Having said that, I believe the actual difference between quality thermal materials is very, very small.
