Does it really make a difference when you are sub zero?
robberbaron
I notice that the Prometeia Mach II is rated at -28° wheras the GT version, which is $150 more, is rated at -40°C. Is there really a performance difference between the temps or is it a gimmick?
I don't think you'd see much difference. You may be able to squeeze out of a few more megahertz, but I don't think you'll get much more.
The different is...... colder load cpu temp.on higher volt and higher Mhz.with GT.
