depends on the situation. If your trying to run in dual channel the same two sticks should be put in the correct slots. I wouldn't worry about it though, you should be fine.
how did the ram come in the first place? usually 1+3 = dual channel, so you'll want the XMS in those two slots and the original ram in 2+4.. but as qwerty implied, it depends on your mobo
