Does it exist?
jstenuf
I want to upgade from socket 754 to 939, but I do not want to trash my 6800 GT in the process. Is there a MB that has both AGP and PCIe capability with an NForce chipset? Price is not an issue.
Thanks everyone.
I know there are a few intel based boards that support both. Nforce3 is only AGP and nforce 4 is only PCIe. Unless you want to go for some halfassed chipset like via or sis, you're out of luck (correct me if I'm wrong)
just get a 939 AGP board. Both nvidia and ati will be putting out PCIe and AGP versions of all of their high end cards for probably 2 more years, which is about as long as socket 939 is likely to last.
VIA was releasing a chipset that supported both AGP and PCI-E, but I don't know if it's available as of yet.
VIA is a bad chipset :confused: i was just going through their kt880 or w/e and that looks nice, especially for socket A boards cause then it supports dual-channel
wow....can you guys stop making retarded statements?
A. The VIA k8 chipsets aren't bad...in fact, their quite good.
B. The SiS chipsets are just as good as the nV ones, they just don't have the support
C. VIA is not a chipset. It's a company................
the k8t890 should support both, and it should be out soon. I wouldn't bother upgrading now, though
I was just replying to this guys comment, cause i used the kt600 on an ECS board. Man that was a fine set-up, especially since the mobo was only $40 :cool:
there are a couple of nf4 boards with pcie and agp. probably tier 2 and 3 brands like ecs, biostar, etc. there are also a couple of nf3 boards with sock 939 and sock 754 sockets(can only use 1). i think kt890 (via) supports agp and pcie. google this and you will come up with it. actually finding 1 for sale is something else tho.
very truly yours,
politenessman
A: - High Rate of failure, plus High rate of incompatibility Issues. : What would you consider good? "It boots, so it's fantastic?"
B: Economy Chipset. The celeron of CHipsets. No.. wait.. The Cyrix of chipsets.
Performance is sub-par on matched platforms.
C: Via is a company that makes chipsets. Such as the "Via KT880" so, when someone says "i've got a via chipset" they are saying "I have a chipset by VIA company"
much like saying "I've got a CHEVY" or "I've got an Intel"
A chevy is no more a car, than an intel is a processor, or via is a chipset. However, a Chevy [insert car type here], Intel [insert processor model here], or via [insert chipset model here] are "understood when someone says it.
This is the english language, Welcome to it, Enjoy It. Many things are "understood" although not said. The term for this is "imply" as in to refer to something without directly mentioning it.
check that - kt890 is not agp/pcie as far as i can tell. i think the pt890 for intel does have this feature.
very truly yours,
politenessman
Laforge said:
A: - C: Via is a company that makes chipsets. Such as the "Via KT880" so, when someone says "i've got a via chipset" they are saying "I have a chipset by VIA company"
Why are you so angry, who cares if its a company easier to just say via chipset. Cause via made it and its a chipset hence via chipset.
I personally have no issues with VIA. I have used MANY MANY of their chipsets.
The KT133 chipset did have some issues with compatibility (especially with Soundblaster products at the time) but... NVidia had IDE issues, SiS was typically the lowest of the bunch.
ALL chipsets have some issues... some are better than others. I hate generalizations. 'Tis like saying "the AMD K5 chip sucks ass, so the A64 must suck too."
I don't think so.
Buy the best you can at the time from whatever company.
-Skystalker
I'll vouch that VIA is decent. I've had great luck with many boards based on their chipsets. However, I've never used them in an overclocking situation.
As for SIS, I've had problems with some of their chipsets. However, their newer ones seem much better.
Dorkboy.
I *WAS* replying to bountyhunter who said that via was not a chipset.
When I look at something that says via kt800 on it, I tend to think that it's a chipset
It was *bountyhunter* who said via was not a chipset.
Just get a nice, sub $100 AGP nforce 3 chipset board, then, when you are ready to upgrade to PCI-E card, get a better Nforce 4 mobo.
PT880 Pro, for P4, natively supports AGP & PEG.
VIA makes decently-robust chipsets, but I am still uncomfortable using them because of their previous problems with graphics incompatibilities. I couldn't find a single video card with which my old dual-370 (Apollo Pro 133A) board could run AGP4x, regardless of manufacturer. The same board is now having problems running with Radeons in general. It was well known that their AGP4x chipsets had problems running at 4x, and even some of their early 8x flavors couldn't run 8x!
I know that most people say these issues are a thing of the past, but one of my recent P4 builds (Gigabyte 8I915P Duo Pro, 3.2E) ended up having incompatibilities between the X700 Pro and VIA RAID controller. These were resolved with a HighPoint RAID controller, but the board was brand new, and latest-generation chipset! I am very happy with my current NF2 motherboard, and will soon be very happy with my NF3 (knock on wood)!
