I want a switch box I can plug in all of my computers sound cards to along with my headphones/mic to.
Is there a switch box out there that will accept
Incoming:
Inputs (Front R/L, Rear R/L, and Center/Sub - 6 total RCA's per PC, or 3 total Stereo 1/8" jacks)
Mic Output per PC as well
Up to 3 PC's / 2 at minimum
Outgoing:
Headset: The typical 1/8" plugs for a set of headphones (1 - Front R/L, 1 - Rear R/L, and 1 - Center/Sub), plus the 1/8" Mic plug (Incoming) and the USB Plug for power
(I currently have a set of Razer Baracuda Heaphones that have the 4 -1/8" plugs and 1 USB plug and I know other 5.1 headphones do as well)
Speakers: 3 - 1/8" Jacks to go to speakers (1 - Front R/L, 1 - Rear R/L, and 1 - Center/Sub)
Function:
Will allow a user to Turn on or off the inputs from any source
Will allow the user to switch between headphones or speakers with ease or send any source to headphones while sending different source/s to speakers, or any combination of.
Right now if I want to go from speakers to headset, I have to get up and plug my headphones into my sound card, unplugging my speakers. Then have to switch again if I want to listen to speakers. I also have one main speaker system and one main set of headphones but 3 PC's within proximity of each other. I would like to be able to have them all send the sound to the single speaker set or headphones (however I wish) or be able to isolate and only listen to one source and turn the others off. I would also like to use the Mic on the headset on any PC connected. This would require a central switch box - is there one out there that is set up for 5.1 set ups? I have found one by Plantronics for a 2 speaker set up and headphones, but that is it.
Any help?
Incoming:
Outgoing:
Function:
Any help?
