When I had a P45 board with a q6600, my cpu cooler took up 1 ram spot. I used 3 sticks of gskill 2gb ram. System posted with "Flex" memory enabled. Basically it used dual channel for 4gbs, then single channel when it needed to access the last 2 gb.
Does this still work on newer Intel Chipsets? My Thermalright Macho takes up a ram slot on my Asrock Z87 killer. I can buy an extra 4gb stick for pretty cheap.
would it run:
12gb single channel
8gb dual, 4gb single in Flex???
Thanks,
Jimmy
would it run:
12gb single channel
Thanks,
Jimmy
