Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Mostly no since 4 cores is already enough. Most games are not optimized to use more. I guess if you get an i3 that has 2 cores HT would help the few games that can use 4 cores.
I've read it actually hurts performance in games, but the performance difference is so negligible that its better to leave it on since it helps for regular usage.
It can hurt if the scheduler inefficiently handles what threads go on the logical cores or it keeps switching what cores get what threads. Basically if you use windows XP you will see this problem more than if you use Windows 7 which is aware of the logical and physical threads.
From my casual observation of benchmarks, Inotocracy is right, hyperthreading hurts gaming performance, even just a little. I've always considered it a worthless Intel feature because games are the only place where CPU speed is critical to me. Even in the best non-gaming cases, hyperthreading is far from the performance that another real core would provide.
