note that this will reduce contrast since you're reducing the white level but not altering backlight brightness.
or you could try lowering white level using the brightness control in your video driver's control panel.
lowering white levels digitally this way, or by lowering the rgb values in the osd, will always reduce contrast since the black level remains the same. if you're okay with the black level at maximum backlight intensity (max brightness in osd), then it shouldn't be a problem.
