Does Doom 3 force Tri-Linear Filtering?
medium
I'm not at home, and I just thought about this, wondering if it's true. I'd like to turn it off and only keep the 8xAF instead. Perhaps I can force bi-linear in the driver/control panel?
Doom 3 doesn't give you the option of running bilinear filtering by default. If you want to run with bilinear filtering, add this line to your autoexec.cfg:
seta image_filter GL_LINEAR_MIPMAP_NEAREST
This can also be entered into the console. It will create a noticeable visual quality downgrade, but improves performance substantially on older video cards. The setting is especially useful for 64 MB cards. If you want to change it back to trilinear, use the same command but with GL_LINEAR_MIPMAP_LINEAR.
