Hi all !
I'm new in this very fine place. Most of my Google searches ended up here, you all seem so knowledgeable, I hope I can learn from you guys. As the topic's title says, I was wondering if the FSB on the cpu has an effect on the voltage I'd need to OC ?
[Note: the following is over dramatic and over detailed and may not suit people in a C.B.A. mood
Let me explain a little more. My current rig was purchased in summer 2003 (Northwood PIV, 3.0ghz).So as you may think, it's getting old, and since I am a gamer, it was time for a change. Unfortunately I didn't know OCing existed at the time, so when I did discover it, it was a little too late since I had not purchased the most oc'able stuff. Now things have changed.
After a lot of reading and research, I have ordered the P5B Deluxe and E6600. It took me a while to settle on the rams, but after a lot of research, I settled on the Teamgroup Xtreem Kit 2x1024MB DDR2-667 3-3-3-8. Fine D9 rams which has seen very interested results.
[Note: the following is more on point with the original question, you may stop skipping here
Which brings me back to my original question. I'll be cooling the E6600 with an Ultra-120 and a Scythe Mineba, the whole thing in a Stacker 830 Evolution. So for cooling I'll be all set pretty much. I've seen this Teamgroup hit DDR2-1100@ CL4-4-4-12 @ 2.2v pretty much without too much hassle, and I had hopes to OC my E6600 at least up to 3.6ghz, maybe 3.8ghz.
So it all comes to this. If I do reach DDR2-1000 in CL4 which is pretty good imho, I'd rather keep the CPU in a 1:1 ratio, so if I use:
543mhz * 7 = 3801 mhz
or
423mhz * 9 = 3807mhz
Same clock, but better FSB. According to my readings, the higher the FSB the better right? But does the FSB affect the vCore I'll have to use? If so I'll have better chances at hitting 3.8 using a high multiplier. It'd be a shame though, since I'd have to underclock the rams or use a 4:5 ratio on the rams to keep them up. I wonder what would give me the highest performance though?
So anyway, I hope this wasn't too messed up of a post, I'm just preparing myself mentally for when my rig arrives as to enjoy the Overclocking session
Any inputs would be appreciated !
Thanks a lot
or
Thanks a lot
