Does Clarkdale support TV-out VGA?
That is, can it output composite or S-Video on the VGA pins like some video cards support?
http://www.amazon.com/VGA-to-S-Video-RCA-Adaptor/dp/B000P3UB24
I need to hook a board with Clarkdale integrated graphics VGA/DVI/HDMI ports to an older TV with only S-video and composite inputs. I can't find any official specs on the matter, so wondering if anyone's done it or has a better suggestion?
if you have a h55 mobo you can possibly try this.....hdmi to dvi cable then run your audio via optical or spdif to your receiver or have stereo out to speakers,,,,,not saying that it will work but thats what I come up with off the top of my head. HTH.
Judging by those reviews on that cable, it isn't very likely that it will work. Most video cards that have tv out usually don't use the vga port. I doubt the h55 will either since it has even less features. But as onyxbfly said you can try, the cable is like $3 plus shipping not going to lose much.
My TV only has S-video and composite. I haven't seen any DVI to S-Video/Composite adapters that don't require a hardware converter.
In order to receive proper help I think we are going to need more info from you...System specs i.e. model of parst etc and the make and model of your tv, and pls include any other variables that may be involved etc i.e receiver etc.
