FS Effects
- Mar 28, 2006
some reviews i read over at newegg stating "this is a quiet case"
what the... it's just a case.
You have three PC's and not a single one of them has ANY fans at all whatsoever?FS Effects said:I have own 3 pc's and none of them came with a fan.
SuperSubZero said:You have three PC's and not a single one of them has ANY fans at all whatsoever?
You either have a pre-made water-cooling setup or you run a 486DX-33 or something.
A well-made case will have fans strategically placed to provide proper cooling but at the same time move the air without causing alot of "turbulence" and vibrations that can make a case noisy. Typical computer cases have a fan or two up front, one in the back, a CPU fan, a video card fan, maybe a fan in the top and/or side.. everything is pointing all different directions too. A well-made case can properly channel all of these different currents and do it without making the PC sound like there's a tornado happening inside.
Incorrect. Aluminum tends to resonate more which then creates more noise. The quietest cases are steel cases.m3ta1head said:Certain materials, aluminum being one, dampen noise from fans better than say, steel.
