Does BenQ e2400HD do 75hz (DVI)?
BM00
Can't quite find the answer to this question. The last 2 16:9 screens I had could only go up to 60hz at ALL resolutions. I'd like at least 1 or 2 resolutions able to do 75hz (DVI) since a few older games I play look and feel better with 75hz. I don't care if it's dropping a 5th frame, there is a noticeable and stark difference from 60-75hz when frames are capped at 300+.
Any BenQ e2400HD owners out there that can answer this for me? You can use Rivatuner to see low-level refresh settings or ATI control panel will tell the maximum refresh rate in the "Digital panel" DVI area.
Appreciate any help
Only through VGA at any usable resolution.
Through DVI I think it's only 1024x768.
I realize it can't do 75hz @ 1920x1080. I meant does it support 75hz at any resolution when using DVI? Even if it's a 5:4 or 16:10 resolution - 75hz is welcome.
