Can I play the dvd in my computer and pass my reciever the DVD-Audio mix though my spidf out?
neokeelo said:Im just trying to use my computer to play it instead of buying a new dvd player with dvd-audio decoding on it.
Moofasa~ said:You can, but you have to get an Audigy 2 or X-Fi card and hook up your sound card to your receiver by using the analog inputs on your receiver. You would have to use the analog inputs too if you were to buy a dvd player that supports DVD-Audio. You cannot output DVD-Audio over the SPDIF ever.
Lomic said:Just to ask, what kind of speakers or headphones are you going to be using? You need pretty decent gear to hear a real difference between high bitrate DTS and DVD-Audio. Just before you possibly spend money on a new player. Also be aware lower end players with DVD-Audio support tend to have little or no bass management, so the low end (frequency wise) might not be too pleasing.
