Does anyone own a PC-V354?
Diverge
If you do, can you do me a favor and check if 2 x 120mm fans will sit side by side on the bottom of the case and not interfere with the side panels?
The case is listed as 245mm, and I'm curious if I can fit a MagiCool XTREME QUAD 480 Radiator in the case if I gut the drive bays and trim the 5'1/4 drive bay bracket. The rad is listed at 241mm at it's shortest dimension.
Bump as I'm curious as well. I have similar plans, although I just want to put a double rad in the front of the case (for the time being).
There is a whole thread about the V354. Pretty sure most of the information is there...
nice thread crapping.. The OP's question was specific & detailed & doesn't need to be in the main v354 thread as they are not asking to have a discussion about the case. There just asking for a specific dimension
Thread crapping: that's interesting. By your logic every time someone has a new specific question about a case they should start a new thread?
Anyway the whole point of asking the question in the thread is that people who contribute to it will be more likely to help...
If he was asking about your opinions on the case then it would be best int he discussion thread.. But if its a specific question such a measurement & no further discussion is needed then that would be the end of it & it could be its own thread..
Otherwise by your logic you should never create a post if its about a product that has been discussed before. They should always be in the same thread.. That would get pretty hard to follow. Oh & ya know the other thread about what PSU for a q07 that you been posting in.. Some of the PSU's have there own threads & the q07 has at-least 1 or 2 of its own.. so should that guy not have posted a thread either, instead shot hope his question gets answered in a 50 page thread..
Guys, keep your tutus on and let's actually move on to answering some questions!
Am curious about this one myself.
And for future reference there is no reason to necro a dead thread to tell people to keep there tutu's on.
