Feb 25, 2012 #1 K kageon1 Limp Gawd Joined Nov 12, 2006 Messages 173 Deleted Last edited: Dec 21, 2013
Feb 25, 2012 #2 R recklessfour n00b Joined Mar 11, 2009 Messages 59 I know some sites that offer the service like performance PC or frozen cpu. But if you trying to take it locally, i'm not quite sure.
Feb 26, 2012 #3 S Scofflaw n00b Joined Sep 18, 2011 Messages 10 If you just need the metal cut, try the Torchmate section on Pirate4x4. They are pretty good at cutting them out, and someone may even have a router setup to cut plexi.
Feb 26, 2012 #4 C Cruiza [H]ard|Gawd Joined Mar 17, 2008 Messages 1,701 No clue what the cost would be, but some local metal shop might do it for you.
Feb 26, 2012 #6 M Magnus [H]ard|Gawd Joined Jun 4, 2004 Messages 1,183 Cruiza said: No clue what the cost would be, but some local metal shop might do it for you. Click to expand... Yup, many metal and plastic fab shops have laser cutters that would do a nice job and local is usually cheaper.
Feb 27, 2012 #7 ThE_MaD_ShOt Limp Gawd 2FA Joined Feb 18, 2012 Messages 244 Yes try and local metal working shop or even a Body shop may be able to do it.
