Aug 24, 2009 #1 B Bviper Weaksauce Joined Oct 20, 2008 Messages 117 Trying to setup a VPN connection (using OpenVPN) and would like Vista to not mark the connection as "Unidentified connection" The tunnel works exactly how it should, except this one small caveat.
Aug 25, 2009 #2 B BigD1108 Limp Gawd Joined Nov 6, 2008 Messages 165 You can just go into Network and Sharing Center and under "View your active networks" click on the icon for the network, and rename it to whatever you like.
Aug 25, 2009 #3 D Deleted member 12106 Guest I believe there is also a GPO to change its default setting for unidentified networks.
