does anyone know anything about Silverstone Multi Panel
True, my bad. To comment on the one you were looking at, I've seen similar, and they look somewhat cheesey and aren't constructed all that well. Also, they add a lot of cable clutter unless you have a really good setup for organizing the cables in your case. I'd be really picky about getting one of these, making sure it was not only completely made of metal, but also had a VFD or dot-matrix LED display. Unfortunately, most of those models are expensive, but they look a ton better and some are even programmable.
yea im gone go with The black Silverstone SST-FP52-S. Solid metal construction. Has everything and more. Automaticly adjusts your fans to case temp. Has Led. This one is the chosen one!, and it is adjustable and programmable So i think this is it..if you have read more about it You would not talk about if it was gone be metal or not. It is.
The ones I would defently stay away from are the cooler master LEd. They are so inaccurate and don't work properly sometimes. Plus they are cheap construction! I had one before and I returned it.
