Does anyone know about the Monarch HornetPro?
Blananar
Does anyone know anything about this SFF? It is a bigger than normal SFF, with space for a GeForce 6800 and room to spare. I am planning on getting it, with my future system, down the way, but I want to know what you guys have to say about it...
Hornet Pro.
Input is highly appreciated...
It really is quite a bit larger than most SFF and looks a little like a file cabnet with that small handle bar on the front panel. Other than that, I think it is a tremendous value. If you have money to spare (and I do mean lots), you may want to take a look at Falcon NW's new FragBox 2 as well:
http://www.falcon-nw.com
It is smaller than the Hornet Pro but has room for a standard ATX power supply.
Well, I don't have money to spare, and I like the fact that I can have the option of no logo, so, I think I'll stick with the Hornet Pro...
I think maximum PC did a review a couple months ago...I think it got an 8 our of 10. I'm not sure on what the score was...so you should probably look it up.
Which version of the 6800? I thought the 6800 required a 480W power supply?
Well, if you look at the pictures of the back of the case, it looks like it might be possible to cut out a larger portion of the back, beneath the power supply space, to fit in a full ATX PSU... Would this be possible? That's what it is looking like I should do, if I want 2 GeForce 6 series PCI-E cards in SLI... (BTW :: I'm getting it dual 6600 GTs... $400 is never spent better, IMO...)
Haha, I was thinking about that too, a SFF with SLI! However, most of these cases are looking like they are pushing the thermal envelop already with just one 6800 card so even with a proper 550W power supply, they may still have problems. I guess this is where custom mods come in?
Well, I'm gonna use a custom built external/internal watercooling unit, and also, the power supply might be so big that it will go part way outside of the case (can anyone assure me that this won't happen?)...
BTW :: The Hornet Pro got the Maximum PC Kick Ass Product award...
the NVidia guy @ quakecon said the performance between two 6600gt in SLi -vs- the 6800gt, is pretty damn close
