Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Buying for a friend for a wedding present to throw some parts in (he really needs a computer) but unfortunately price is an issue. I've seen some great deals in the past but am having a hard time finding one when I need it. Thanks in advance!
Antec and Coolermaster are the only two brands that offer decent PSUs bundled with some of their cases. Coolermaster's good ones are generally somewhat expensive, so if you're budget-minded, an Antec bundle would be your best shot. Double-check here before you pull the trigger on anything so we can have a look at specifically which PSU you'll end up with and whether or not it's any good.
If price is an issue you kinda need to state a price. Antec is pretty much the only combo i'd go with, also Lian li has been bundling with Seasonic on Newegg. You could always buy them seperate...
