I'm a Firestone fan and I noticed yesterday that they now make mono blocks.
The specs look pretty darn impressive and they certainly walk all over my Big Joe 1.3 in terms of wattage, at quite literally 5.5 times more wattage per channel. The Big Joe is quite impressive at 8 watts per channel, believe it or not, I'm quite looking forward to the clean power of these new amps. As Big Joe is now, it's quite impressive in near field in conjunction with a sub. It sounds like a much bigger system not to mention far superior audio quality over every receiver I've ever owned (JVC, Techniques, Sony, Pioneer).
Big Joe IV Mono Block specs:
Amplifier Structure : Coupling capacitor, Mono-Mono Class-D Amplifier
Power Structure : Soft-Start circuit, Single-supply
Sampling Rate : 96kHz / 24bit
Power Output : 8ohm @ 44W (0.3%THD), 4ohm @ 80W (0.3%THD) / 100W (10%THD)
Circuit Protect : Output short / over current / over and under voltage / temperature protect
Characteristic : Built in high quality WIMA capacitor and inductor
Power Stage : TI - TAS5121
PWM Controller : TI - TAS5010
ADC Chip : TI - PCM1803A
Does anyone use mono blocks, and beside the obvious increase in wattage I'd get, what benefits do you think they'll offer?
(No, I will not be selling my Big Joe!
Here's a pic of the mono blocks sitting at the bottom of the new (way overpriced) audio rack:
