I thought I'd enable it on my e6300 (via bios and windows) just to see if my idle temps go down even further, currently they are between 35-40C depending on how hot it is in the room. I know, the temps are nothing to worry about, I'm just being kind of anal with my idle temps, anyway, back to the EIST question
So with EIST enabled, when the CPU is doing nothing, it only gets throttled back to 1.58GHz from 1.86GHz (running stock speeds, no OC). Seems like a pretty worthless amount throttling, seeing it's only <300MHz difference, not to mention, it does next to nothing for my core temps and vcore voltage. Core temp doesn't get any cooler and vcore voltage only goes down between .02-.04V.
Anyway, is my EIST working properly?
